メインコンテンツにスキップ
モデル番号A1502 / 2.4, 2.6, 2.8 GHz デュアルコアIntelプロセッサ/ 2013年10月発売
552回答 すべてを表示
OS X does not inicialize
When I turn on my Mac, it just processes and finally It shut down instantly without entering the system what it may be? I tried to enter into security mode, but the same happens, I entered the recovery partition and tried to repair the disk, the Repair process fails and asks to backup the information, but without entering the system I can not back up the information, what I do now, how do I save all my information and recover the system? I have no time machine backup,
Update (12/27/2016)
Has no external ssd drive nor onther macbook with same ssd compatible, is ther onther option to same my information ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Do you have access to a second Mac? If you do you could try using Target Mode. The other option here is to take the SSD drive out and using a special case mount it into it which will allow you to access the files to a second Mac system.
If target Mode won't work you'll need to use the case method. It does sound like your system has a deeper issue here which is why it's shutting down. Once you get your files off the drive you'll likely need to look deeper on whats happening here.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
target disk mode or external SSD adapter would solve ur issue
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Aristides Guirrengane さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 8
今までの合計 48
