メインコンテンツにスキップ
Appleの2016年ラップトップラインアップの最新モデルは、プロフェッショナルユーザーを対象としています。 15インチ、2880 x 1800 Retinaディスプレイ、クアッドコアIntel Core i7、256 GB / 512 GB / 1 TB / 2TBストレージオプション、16 GB RAM、およびTouch Barを搭載したキーボードです。
260回答 すべてを表示
Is the SSD shielded like on the 13" without touch bar?
I've been unable to use any product with a modern SSD due to the noises made by the pulsed operation of fast flash, until the Late 2016 without Touch Bar, where there is a cage around the SSD and seemingly some sort of sound absorbent material., reducing the sound to inaudible levels. Now, I'm looking into the Late 2016 15" with Touch Bar, and wondering if the sound shielding is equally good? The cage is promising, but from the pictures, it appears the absorbent is gone?
If the wonderful folks at iFixit could take a mic to these machines, it would be a great boon to the few people who hear the unbearably synthetic chirping of SSDs and who are looking for computers that don't have it. An FFT from a cheap mic tells me, for a rMBP2015, that the peaks are at ~19kHz and ~21kHz.
Update (12/27/2016)
I'm guessing it's the converter for the write voltage. It's subjectively below 30dB and inaudible when the fan is running. It originates in the area of the SSD and correlates with disk activity. I have recordings. The sound cannot be described by analogy to natural sounds, but the closest would be crickets for intermittent disk activity and, for light to heavy load, a mix of the grinding of a heavily loaded HDD and the fizzing of a carbonated beverage with its cap off. The sound exists on every SSD-equipped portable I have tried. On the new entry level Macbook, it's inaudible to me unless I put my ears within a few inches, making that one a godsend.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Can you please post these recordings I would love to hear what you are hearing.
I have very good hearing in fact I made a big effort to make my home as quiet as I could. As I hate hearing all of the bangs and whirring when I sleep.
Sadly, I don't hear any sound coming from my laptop which I'm working off of right now like you describe. Nor, have I heard any sounds coming from any of the systems I've repaired other than the expected ones. I'll try see if I hear anything on the ones I'm working on this week now that I'm aware of your concern.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Can you explain a bit more here?
Solid state drives (SSD's) don't make any audible noise unlike hard disk drives (HDD's) which have moving parts. Are you hearing the fan's which is the only other moving part in the system?
While some capacitors and inductors can make noise SMT devices used today are less likely to create feedback harmonics that one could hear unlike old fashioned household fluorescent light ballast that could squeal.
The metal shielding around the SSD in the newer non Touch Bar models is for EMI noise which you can't hear. Even a microphone wouldn't hear anything either as the its not sound waves its radio waves (in the microwave realm on the most part).
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
I've worked on six systems now all with SSD's. Three where retina systems, two older MacBook Pro's with SATA SSD drives & a mini.
I was unable to hear any sound coming from the SSD its self the only thing I could hear was the fans. I even disconnected the fans on two just to be sure nothing!
You'll need to post the sound file so I can hear it to see what you have otherwise I can't offer you a reason why you hear something I can't
さんによる
Unless there is something wrong with the power supply (Volts of overcurrent that would destroy it) to the SSD it is impossible to hear the sound it would make with a human ear. I would like to hear what he is hearing to. The first human witnessing of SSD noise!
さんによる
コメントを追加
回答を追加する
Marius Bendiksen さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 16
今までの合計 184
