メインコンテンツにスキップ
13インチアルミ製Unibody, 2.0 or 2.4 GHz Core 2 デュオプロセッサモデルです。
575回答 すべてを表示
Logic board replaced, won't power on.
Liquid damage. Upon disassembly, found logic board burned where hard drive cable connects. Replaced logic board, replaced hard drive cable, reassembled. Connected to power, and it won't turn on. I see the battery indicator, but nothing happens when the power button is pressed.
I found another thread that discussed the possibility of the charger inlet daughter card being faulty, and that you could jumper two solder points to test, but it was a different model macbook (an older one I believe), is that possible with this one? What could the problem be?
I'm new at this, but I was disgustingly meticulous with disassembly and reassembly.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
Look for blackened and or burnt areas or components. Get the battery out ASAP
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Did it just burn the cable or the board also?
さんによる
Here's a replacement hard drive cable, maybe that will suffice: MacBook Unibody (A1278) Hard Drive Cable
さんによる
Unfortunately the board looks pretty toasted at the point where the cable connects, it will need a new cable as well though.
さんによる
Replaced logic board and the cable, won't power on: Logic board replaced, won't power on..
さんによる
コメントを追加
回答を追加する
Patrick さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,883
