メインコンテンツにスキップ
The Xbox One Wireless Controller model 1697 was released in 2015 and replaced the model 1537 controller and fixed some of the problems found on Model 1537 controllers. The Model 1697 controller includes an integrated 3.5mm headset jack, which allows compatibility with most 3rd party headsets without the need of an adapter. This controller has been discontinued and replaced by the Model 1708 controller.
75回答 すべてを表示
Is there a fix for directional "wandering" on Xbox one controllers?
On all three of my XB1 controllers the arrow, reticle, or avatar will move or wander on its own even when not touching thumbsticks: IS THERE A FIX FOR THIS?? or is this how MS gets an extra $70 out of each Xbox owner every few months? ANYONE??
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 10
4 件のコメント
its fairly easy to fix you need to replace the entire stick mechanism inside the controller itself. I just did this job myself, follow the guide for tear down and simply de-solder all 14 points push out from the bottom insert the new mechanism and resolder the devices pins back to the board.
さんによる
You don’t have to take all the points off just find out which one is bad and just take the three points off and then replace that part the green part snap on and off really easy
さんによる
is there not a hard reset like the good old controllers???
さんによる
How do you plan to "reset" a hardware issue?
さんによる
コメントを追加
3件の回答
ベストアンサー
If your Xbox One Wireless Controller has a malfunctioning thumbstick and you cannot properly navigate around your Xbox One, see the Xbox One Wireless Controller Has Malfunctioning Thumbsticks problem page for possible problems and solutions.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
they always seem to start that wander around 4-mos or so "surprise" warranty is 3mos ,btw have you heard of "levity"or do you owe MS something?b'cuz I sure don't,but thanx for nothing tom
さんによる
Interesting. Xbox One controllers are warranted for 1 year here. If you do want to fix it you have to replace the joystick module, which should be available on Alibaba or somewhere. Disassembly and soldering required.
さんによる
Well...u can take the controller apart, super clean the analong bases...rubbing alchohol works....clean teh crap out of it...fixed mine.....
さんによる
コメントを追加
最も参考になった回答
yes you can fix it but you have to be willing to strip down the controller, on a part of the joystick there is a place for a little flat head screwdriver, you have to turn it slightly for it to change the vertical or horizontal scrolling.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
Yes. It's just a cleaning issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
voodoo24u さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 24
過去 30 日: 55
今までの合計 26,405
