メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
Phone only charges when turned off, what needs repair?
Hi guys,
Was interested in repairing my iphone4. The phone works fine except it will only charge when turned off. Battery will hold charge, but it does nothing if plugged if I dont turn it off first. It will charge to 100% when turned off.
What part needs replacing?
Thanks,
Damhan
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
I would actually replace the charging port in this case because the phone turns on and detects the battery and the percentage reading from the battery is fine.
I have had this issue before and it always turned out to be the charging port that needed replacing.
OP: You already tried another charging cable and wall charger adapter right?
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Yep I tried many chargers, I've ordered a battery and a charging port since the battery is probably tired anyway. I'll replace the battery first and if it still isn't working the charging port. May the best man win haha
さんによる
This fixed it. But i'm replacing battery anway since it's tired and loses charge quite quick.
さんによる
Yeah lithium batteries lose around 40% of their charge after being used heavily after 2-3 years.
さんによる
コメントを追加
The first thing I would try is a new battery. The iPhone 4 is old and if the battery is original, it is probably very tired. It could be losing capacity (current) at the same rate as it can accept a charge, hence why it doesn't charge when it is on.
Even a new battery takes longer to charge when it is being used.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
It doesn't even say its charging when i plug it in if its turned on, but I'll give replacing the battery a shot. I'll let you know if it works, thanks for the suggestion.
さんによる
コメントを追加
回答を追加する
Damhan Richardson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 19,461
