will not come out of park
gear shft will not come out park
この質問は役に立ちましたか?
There is usually a release next to the gear shifter. It will be covered over with a piece of plastic on the console, usually about a half inch wide and has a place to stick a flathead screw driver. Pry the plastic piece off and use the end of the screw driver to release the mechanical lock. Then be sure the shifter is adjusted properly as this will cause the button not to be able to release the park lock.
Otherwise, check the brake light fuse which needs to be working to power the lock release with the brake pedal.
Check the fuse first, but if you need to drive you can pop that cover off and unlock manually.
Let us know
Frank
このアンサーは役に立ちましたか?
+ sounds good to me
That release button does not work on mine either how can i take it ooutta park
過去 24時間: 2
過去 7 日: 9
過去 30 日: 29
今までの合計 10,551
