メインコンテンツにスキップ
Appleがプロフェッショナルおよびパワーユーザー向けに提供するノートPCのラインです。現在、MacBook Proには13、14、15、16、17インチがあり、Pre-unibody(オリジナル)、unibody、Retinaディスプレイ、Touch Bar、SOC(システムオンチップ)設計によって大きな改訂が定義されています。
how to i get my wireless to work
how to create a wireless connection
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Please be more specific with your question. Do you have router problems, or is the computer not working as it should?
さんによる
コメントを追加
2件の回答
ベストアンサー
Do you have any other devices which are connecting to your WiFi network? Are they working at the same physical location you are trying to setup this computer?
Look at the settings of one of the working systems to see what you need to set on system that can't connect.
The wireless Bridge or wireless Router (called an Access Point {AP} for either) may also require a given type of 802.11 service (A, B, G or N) or a given band in the case of 802.11n (2.4 or 5.0GHz) for your systems to connect to it. Make sure your system can access the AP's service type settings.
Some older MacBook Pro's can't access 802.11n networks without a firmware upgrade, or access the 2.4 or 5.0GHz bands
How to tell if 802.11n-enabling software is installed:
http://support.apple.com/kb/HT2447
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
If u have a wireless network that you might want to connect to,you reqire the SSID of the network from the network creator,otherwise your wireless wont work.
You can always check the wireless network strength.If it is too low then you wont be able to connect to the Internet.
All the above mentioned solutions are with respect to software alone.You might also want to check if there is any hardware fault with your wireless router or NIC.
さんによる
コメントを追加
最も参考になった回答
Under System Preferences
Network - verify that your Airport card enabled.(turned on) If it's detecting a network (curved arches). If it is then the problem is with your router, check their directions or support pages.
Use Mac Help from Under Help in the Menu:
* Network, share, and go online
  • Your Mac lets you easily join wireless and wired networks, share with others, and exchange information quickly and efficiently while having fun with personal touches.
* Setting up or joining a network
  • '''Whether you’re creating your own AirPort network or joining a local area network at your home or workplace, you’ll find step-by-step instructions to assist you.
If this answer is acceptable please remember to return and mark it.
Good Luck,
N.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
paul さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 1,290
