How to fix a broken screen
The outside screen is fine be in the inside I can't see the screen it look like a crack in the inside.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi
Here is a link to the ifixit guide to replace your screen.
Here is a link to just one supplier of the part. Perhaps you should verify with them that the part is compatible with your model before you purchase if you decide to use them. There are others online if this one doesn't suit you.
http://www.ebay.com/itm/New-LCD-Display-...
Alternatively, if there is a part number stamped on the back of the LCD screen in your tablet, search online using just the number to hopefully find suppliers of the part.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 123
