メインコンテンツにスキップ
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
1525回答 すべてを表示
iPhone 6 Plus tristar replacement
Hello. I have iPhone 6 Plus and I replaced tristar to it. Before repair I tested it with multimeter for how mutch USB cable give power to the battery bracket on logigboard
and the volt was 0.01v and with new tristar the battery bracket gived random volts wery fast 3.50v, 2.45v 1.20v etc. Do anybody have any ideas what is going on? Before repair iPhone wasn't charging or warming at all and no powered on. Screen was black and still is. I have reflowed it without any results.
Any help would be much appreciated.
EDIT 01.08.2017
With new good battery and tristar reflowed once again the iPhone works again.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
Is that with the battery plugged in? Maybe it isn't sensing the gas gauge circuit and dropping the voltage.
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
No, the battery wasn't plugged in when I tested the bracket with multimeter.
さんによる
Take the gas gauge circuit off an old battery and hook the multimeter to the circuit prongs that go to the cell. Then plug it in and try and charge it, the voltage should be around 4.2v
さんによる
Ok. Now I tested the voltage with battery. With USB cable and without USB cable. With cable it show 2.85v and without USB cable 0.65v.
さんによる
Sorry I dont know what "gas gauge" means.. heh. My English is not so good :/
さんによる
The gas gauge is the circut between the battery cell and the logic board, it is the bottom 0.5cm of the battery. You can get it off, but make sure you don't puncture the battery.
さんによる
1以上のコメントを表示
コメントを追加
1st the TriStar is not a charging IC it is a high speed switch that switches between vcc main/vccbatt it also switches cpu and baseband hence the name tri. Tigris is the charging IC. TriStar requires three voltages to function, a reverse gate handshake pin power in. If you have schematics and tools I will help you tomorrow when I am in work
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Thank you for the information. But I already replaced the tristar and now the iPhone works. Thanks
さんによる
can you tell me how you solved this problem to get phone to work please
さんによる
コメントを追加
I have iPhone 6s Plus
Its never charges after 87%, charging very slowly and battery quickly draining
What’s the reason for this problem?
What I do?
Update (01/22/2018)
yes. I already charged 3 batteries and chacked but it’s never charged fully
Never charging after 87%
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
You need to try a new battery first.
But usually slow charging and very fast draining of battery is synonym with short on the board. That would have to be considered next after trying a new battery or at least testing it with "coconut battery."
さんによる
I had the tri star replaced on my iphone 6s plus..now it won't power on at all any suggestions.
さんによる
コメントを追加
回答を追加する
Mobilefi さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 2,695
