メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Screw hole pry damage
Hello. I have iPhone 6 not turning on after screen replacement and iTunes doesen't recognize it. Not heating at all. There are pry damage on the screw hole (middle one) - whole BS2503 is off the board and you can see the copper there. Also it seems that the backlight filter FL2024 is kind slightly burnt. Also there seems to be long screw damage on the two bottom screw (there are copper) but before I take those off and check under those screw holes.. is there anything to do? Please see the pictures.
Is that burnt filter causes that the iPhone is dead or is there something messed up under the middle screw hole? Is that necessary that it is attached to the board?
Any help would be appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
You do not need the metal brackets on the phone to function. You do need the FL2024 to be working, I beleive this is the backlight filter, if this does not work you wont have a backlight. Get a multimeter on both sides and check for continuity, if not then this needs replacing.
That top pic with missing screw anchor is a earth pad at the top layer, iPhone circuit board are multi layered. under the round copper earth there is 1 track. If this is broken this could be causing problems. With long screw damage a long screw is screwed into the hole, screws down too far into the board, then drills its way through the board untill the pad falls off. This type of damage can be very very hard to fix by a pro if not impossible to fix.
The other anchor pads need removing, the black stuff carefully removed from the surface under a microscope to see whats happened under them and see if ant tracks have been snapped. These are however harder to fix if broken as 1 anchor has 3 tracks under it, the other has 9 tracks all within about 1mm width.
http://www.wirescomputing.com/storage/ls...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mobilefi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 1,750
