メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
これはWii Uのビデオゲームコンソールに付いてくるタッチスクリーンコントローラーです。2012年11月18日に発売されました。白と黒のカラーモデルがあります。米国内で発売のモデル番号はWUP-010です。
Gamepad is completely dead
Hi. My Wii U gamedpad is completely dead. I have tried to take out the battery for a few hours and tried to start it without result. The battery has power when I loaded it on the side and measured the voltage in it. Now I screwed apart the gamepad, but nothing is loose and I can not see that any circuit has burned. Is there a fuse in the gamepad that could have tripped? Where? I suspect otherwise there is a circuit board that has given up but which when the gamepad is completely dead? I do not want to spend money on a new one when I plan to buy nintendo switch later next year. Hope you can help me to solve the problem. Sincerely, Raoul
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Thanks for the reply. My gamepad is completely dead, no lights or any lights. How do you mean wifi / bluetooth? Do you now where i can buy parts? the shipping is so expensive from ebay to Scandinavia. :)
さんによる
コメントを追加
2件の回答
最も参考になった回答
More likely than not you're looking at a bad motherboard. If you press the Home button and the power button at the same time does the blue light turn on and then fade away shortly after?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
My gamepad is doing exactly as you have described. The orange light comes on while connected to the charging cable and stays on for a few after disconnecting from charger. When I hold the power button is goes off and when I release and hit the power and home at the same time the blue light flashes for a sec and then goes off ...
Can you explain to me what this could mean kind sir ????
Thanks for any new answers....
さんによる
コメントを追加
Hi Raoul,
I am in a similar situation with a Gamepad, however in my case is quite different.
I replaced the LCD and touch screen and getting response from the touch screen and sounds.
In my case seems to be video related issues, in your case I recommend you to verify the wifi/bluetooth cards.
If any of those are not properly seated or damaged the remote will not power on.
Regards,
JM
Good luck and good repair.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Raoul さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 40
今までの合計 2,683
