メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
My screen seems to be forced in my iPhone
I recently purchased the screen replacement full assembly for my iPhone 6, I followed all procedures but it seems like the screen does not fit completely into the phone, its edges are up and the camera does not function except for the video. The screen seems to be forced, when I barley add any pressure the side acts as if im adding too much pressure.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
The thing is that I ordered the piece from Ifixit, the screen seems yellowish and does not seem to fit, the old screen does.
さんによる
Then send it back.
さんによる
コメントを追加
2件の回答
ベストアンサー
You could have a low quality replacement screen or your housing is dented. See the attached image for an example.
It's a minor dent but it pushes the screen frame down by almost 1 mm. If your housing is damaged, which is not uncommon when a screen is broken, then you need to hammer it (very gently) back into place. I like to use a metal spudger like this . You can use the round end for the corners and the flat end for the straight edges.
Be gentle as the aluminum housing can break very easily.
このアンサーは役に立ちましたか?
スコア 5
コメントを追加
You can get a High-quality iPhone 6 LCD screen replacement in Etrade.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Marcelo Marquez さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 3
今までの合計 69
