メインコンテンツにスキップ
半田付けは、2枚の金属の間にフィラーとなる別の金属を溶かして接続する方法です。 はんだ付けには多くの種類がありますが、この記事では電気を使った半田付けの基本について扱っています。
56回答 すべてを表示
Best cheap-o soldering pencil? (Under $40?)
Hello,
I want to start doing board lever repair for iPhones. I am on a really cheap budget, and I need a really cheapo soldering pencil and soldering tweezers. Doesn't anyone have any recommendations?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
1 件の回答
ベストアンサー
Soldering tweezers and soldering pencils are usually way over your budget. Best thing to do is get a cheap hot air station and a soldering iron, so you can use hot air to remove the component, put fresh solder on using the iron, then use hot air to put the new component on. As long as you don't go crazy with the hot air, and cover important BGA ICs, you will manage fine.
I started off with a combo solder iron and hot air station for £40 and was doing fine. Once you get more income doing board repairs, you can reinvest into better equipment.
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
Thanks, do you think this one will work?
http://www.ebay.com/itm/2in1-Soldering-S...
さんによる
@gigabit87898 , that looks like a good start, maybe just have to find a few different tweezers to add to it, see what others think to.
さんによる
@gigabit87898 looks fine, I got a no brand one as my first (said 898D+ on it) which was good, still use the hot air station as a secondary station, has no problems removing ICs on Macbook boards
さんによる
@gigabit87898 @mayer was using a set like this, he mentioned it a while ago . He seemed to like it Its a good place to start. If your going to do anything along these lines make sure to get a hot air station with it and that it has temp control . I do a lot of this kind of work and if your looking to learn check out
Louis Rossmann https://www.youtube.com/channel/UCl2mFZo... and https://www.youtube.com/watch?v=A0OiT9e_... jessabethany here on ifixit
さんによる
コメントを追加
回答を追加する
Gigabit87898 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 11
今までの合計 604
