メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
iPhone reboots into recovery mode even after restore
Weird problem that i have been encountering with my iphone 6. Every time i turn my phone off, it reboots into recovery mode. So i restore the phone and when it is freshly restored, it still reboots to recovery mode! i really don't know what to do except to never turn my phone off now.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
3 件のコメント
Is the computer recognizing the phone?
さんによる
Yes, the computer recognizes the phone and I tried multiple computers
さんによる
Hello? You still there, has the problem been resolved?
さんによる
コメントを追加
2件の回答
最も参考になった回答
try to restore it in (DFU) mode by following these steps:
*before that If you see the battery charge warning, let the device charge at least for 15 minutes
1. disconnect usb cable from the iPhone, but leave the
other end connected to your computer.
2. turn off your iPhone by pressing and hold the power button for a few seconds
until the red slider appears, then slide the slider. wait for the device to turn off.
If you cannot turn off the device using the slider, press and hold the
power button and home buttons at the same time. when the device turns off,
release both buttons.
3. while pressing and holding the Home button, reconnect the usb cable to the
device. The device should turn on.
4. keep holding the home button until you see the "Connect to iTunes" screen.
as soon as this screen show up release the home button.
6. then use itunes to restore the device.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Still happens even after the dfu restore. Thank you for attempting to help :)
さんによる
コメントを追加
Try rolling back the OS from iTunes on the computer and then re update from the phone then see if the problem persists
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Saleem さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 187
