Drive belt replacement, replacement parts
Where can I obtain a replacement drive belt for this unit?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@cestrangio , Christopher use the links below, 1st link is Sony parts page where you could inquire about availability and the other links are belt suppliers that may have a suitable replacement for your M430. Good luck.
https://esupport.sony.com/US/p/model-acc...
http://www.thevoiceofmusic.com/catalog/t...
このアンサーは役に立ちましたか?
@lpfaff1 Wow I'm impressed you were able to find anything on something so old . Nicely done
@jimfixer , thanks Jim, and what about you where did you find that B code, I thought they only went up to B3000, good job on that one.
If ever you need belts here is one good resource for most belts. Although would you believe the one being asked about wasn't there!
@cestrangio and just in case you need it, the Sony part number for the belt is 3-377-420-11
過去 24時間: 1
過去 7 日: 10
過去 30 日: 25
今までの合計 2,915
