メインコンテンツにスキップ
Sony M-430 Microcassette-Corder can record and play back audio. The one-touch recording and two-speed record/playback and automatic shut-off makes this ideal for on the go recording. Model number M430.
7回答 すべてを表示
Drive belt replacement, replacement parts
Where can I obtain a replacement drive belt for this unit?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
@cestrangio , Christopher use the links below, 1st link is Sony parts page where you could inquire about availability and the other links are belt suppliers that may have a suitable replacement for your M430. Good luck.
https://esupport.sony.com/US/p/model-acc...
http://www.thevoiceofmusic.com/catalog/t...
https://www.kenselectronics.com/lists/be...
http://www.gbaudio.co.uk/data/belts2.htm
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
@lpfaff1 Wow I'm impressed you were able to find anything on something so old . Nicely done
さんによる
@jimfixer , thanks Jim, and what about you where did you find that B code, I thought they only went up to B3000, good job on that one.
さんによる
Hi @jimfixer and @lpfaff1
If ever you need belts here is one good resource for most belts. Although would you believe the one being asked about wasn't there!
http://www.russellind.com/client/downloa...
さんによる
@cestrangio and just in case you need it, the Sony part number for the belt is 3-377-420-11
さんによる
コメントを追加
回答を追加する
Christopher Strangio さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 28
今までの合計 2,573
