メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Slate 7 Plus 4200USは、高速で多機能なタブレットです。Webブラウジングや写真撮影、高品質なゲームプレイが可能です。
Screen unresponsive to touch
The screen on my tablet is stuck on the main screen and not responding to touch.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Check to see if you have any apps open and running in the background. Try closing them all. If this does not work, check the HP Slate 7 Plus Troubleshooting page where it will show you how to perform a soft reset, hard reset, and a factory reset.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have the same problem on my HP Slate 7 Plus; touch screen gradually failed. I attempted repair, and checked all connections, however although I was able to get the LCD screen to work properly, the touch screen is completely dead. As of this date, I could find no replacements for the HP Slate 7 Plus, either new or used. (The HP Slate 7 is a different model, and those parts won’t work).
You can get around the touch screen however, by using a USB mouse, and a micro USB to USB adapter cable adapter (female socket). Android system will apparently recognize a mouse attached to the micro USB port on the tablet, and will present a cursor which can be moved around to select what you’d otherwise be able to do with your finger if the touch screen still worked. Pretty clumsy second choice, but at least the tablet can still be manipulated with that.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jessica Andrade さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 20
今までの合計 514
