メインコンテンツにスキップ
New SSD installed, need to install Mac OS
I have a 2009 mac mini, I replaced the dead hard drive with a new SSD, I have the original disks that came with the mac mini, but when I inserted the disk, I only get the flashing folder with the question mark.
what should i get the mini to recognize the recovery disk?
I tried the boot up with the Command+d, command =r, and the command+option+d and nothing happens.
Any help will be appreciated.
Mike
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Hello,
With the mac mini off keep option/alt key pressed and turn the computer on and keep the key pressed until you see the partition or cd drive option to chose. Try and see if you can chose to boot from cd like that.
さんによる
I'm having the same problem, t'm trying to do a clean re-install. A message says it's taking about 17 minutes, then I get no packages were eligible-to install
さんによる
コメントを追加
1 件の回答
ベストアンサー
Have the disk ready to insert. Press the power on button and immediately hold down the "C" key on start up. Go to the second page of the installation and the pull down menu will appear. Go to Disk Utilities and format the new drive GUID & Mac OS Extended. Now you can install the system.
Also check the specs on your new SSD drive to see if it backward compatible to SATA I, 1.5 GHz/s, many are not.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Mike Ibarra さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 389
