New SSD installed, need to install Mac OS
I have a 2009 mac mini, I replaced the dead hard drive with a new SSD, I have the original disks that came with the mac mini, but when I inserted the disk, I only get the flashing folder with the question mark.
what should i get the mini to recognize the recovery disk?
I tried the boot up with the Command+d, command =r, and the command+option+d and nothing happens.
Any help will be appreciated.
Mike
この質問は役に立ちましたか?
2 件のコメント
Hello,
With the mac mini off keep option/alt key pressed and turn the computer on and keep the key pressed until you see the partition or cd drive option to chose. Try and see if you can chose to boot from cd like that.
Alex さんによる
I'm having the same problem, t'm trying to do a clean re-install. A message says it's taking about 17 minutes, then I get no packages were eligible-to install
Bill Condie さんによる
