メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年9月25日に発売。モデルA1687/A1634。このデバイスの修理は前モデルと似ています。スクリュードライバーとこじ開けるツールが必要です。GSM もしくは CDMA。容量は16、64か128 GB。カラーはシルバー、ゴールド、スペースグレイ、ローズゴールド。
restore not working iPhone
Hi all,
my iPhone suddenly decide not work, I went to apple store they can replace it but not fix it. they recommend to me a repair store which cost me 1000$.
anyway can help to backup at least the photos,,,please
abounded thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
9件の回答
ベストアンサー
Please take these steps and post your results. It will help us narrow down the problem:
1. Connect your phone to your computer. Does your computer see it?
2. With your phone connected to your computer, hold down the power button for 5 seconds. While still holding power, press and hold the home button for 15 seconds. Once the Apple logo appears, release the power button while still holding the home button. Does iTunes see the phone now? Does the display work now?
The answers to those questions will help us a lot.
このアンサーは役に立ちましたか?
スコア 3
7 件のコメント:
Hi,
1. when the phone connected the computer cant see it.
2. nothing happened at all. the screen is black.
thanks
さんによる
OK...that tells me that the phone has some issues. Its not powering up at all, even on the charger. So there are a few things that could be wrong. The Lightning port is a possibility. Could also be a bad battery. Neither of those are likely, they are possible though. More likely is the logic board of the phone suffered damage by getting wet, getting dropped or by using non-MFI certified chargers and cables.
You could through a new Lightning port and battery on it to make sure, but it does not sound good.
さんによる
Josh made excellent troubleshooting recommendations. Without knowing the history of your phone prior to failure, it is impossible to diagnose. If you can, please tell us more about what happened to your phone.
If you don't have the experience or the tools necessary, you should consult with a qualified repair shop that does micro soldering for a proper repair or data recovery.
さんによる
I feel kind of bad because with Apple phones, the answer is usually "Your board is fried and it needs expensive repairs that maybe 15 people in the entire country can do".
Sucks
さんによる
thank you all for cooperation,
I think doing ethier
1- changing the battery
2- putting the logic board in other iPhone
but the question, am I going to loss the data?
さんによる
2件以上のコメントを表示
コメントを追加
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Data will not be lost when trying the logic board in another housing. I doubt it would help at all because the logic board is basically the whole phone.
Changing the battery will not cause the data to be lost as well.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Hi,
thanks
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Sucks
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
as Ben The Great said, neither of those will cause loss of data. They are both very good ideas.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I like the title "Ben The Great" ;-)
さんによる
I think it should be official @mayer
さんによる
コメントを追加
hey
I have had the same problem with my phone.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sabir さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 19
今までの合計 359
