メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
New Battery Draining very quickly
Hello All
Wondering if you could assist with a strange fault.
I have a iphone 5s which I have now replaced TWO original iphone 5s batteries ( I repair phones for a living and have never had this issue)
The problem with both batteries is the following, I charge to 100% and then put it into airplane mode . I leave overnight and within 12 hours the charge has dropped to 50%.
The phone has been factory reseted and has been set up as a blank phone (no apple ID etc).
I do notice the charging symbol stays on once the battery hits 100%
Any advise would be appreciated
Regards
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
This is very strange indeed. I would recommend disconnecting the battery from the motheboard, and holding the sleep wake button for a minute or two. This will discharge the board. I would recommend disconnecting the iPhone's LCD , camera, and earpiece connections as well after disconnecting the battery, but before you discharge the board. Connect the battery after you have reconnected the LCD, camera, and earpiece. Try charging up to 100% and disconnect. Leave the phone in standby and check on it after 12 hours. I hope this helps you, please keep me updated.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Ali さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 67
