メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
My iPhone's screen shows messed up colors
At first my phone's screen stopped responding to my touch momentarily, usually hitting the screen against a flat surface and then turning the screen off and on would fix it. But a few weeks ago I hit it and the colors just like broke. The colors were bars, each bar a different color and only a little tiny corner of the screen would work.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
Thank-you this should help
さんによる
コメントを追加
2件の回答
ベストアンサー
Screen has gone bad. Replacing the front panel will fix the issue.
Guide to replace screen:
iPhone 6のスクリーンの交換
You can get the screen from here if you do choose to do it yourself:
iPhone 6 Screen
You have a few options, take it to a mobile phone repair shop to get the screen replaced (I would avoid shopping malls as they are generally either expensive or not very well experienced in mobile phone repairs).
Or you can choose to do it yourself which is fairly simple if you follow the steps in the guide well. Parts that you need to be careful in specifically are the metal plate for the screen connectors on the logic board (phillips head screws are different sizes for a reason), removing the home button, metal plate for front panel which has the home button extension cable together and the front camera requires some delicate prying.
iPhone 6 Screenの画像
製品
iPhone 6 Screen
$44.99
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
in my settings i have a cpu on or cpu off and when i turn cpu on it shows com.android.systemui and a bunch of numbers and colors example 7.39/in red /7.65 in Green / and 8.08 in Blue does anybody know what that is about ?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
adr123 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 45,932
