メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
iPhone 5 screen is acting weird
My iphone screen suddenly acts weird last 4 days, for example i'm browsing facebook when suddenly the screen freeze or so i thought because i can't scroll down and touch the assistive but when i push the home button it directed me to the home display so it means that the screen didn't freeze it only happened for about 5 seconds, and sometimes when i zoom in i can't zoom out again the picture is either going up or down and then when i tried to compose new message the screen didn't respond and sometimes when i'm trying to swipe the home screen it is swiping but slowly all this is happening for about just 5 or 10 seconds, then it is clicking by itself and just last night i'm scrolling it, it is scrolling but when i touch the words it is not responding, sometimes i can type but when i'm clicking send it doesn't respond but i can still type and it is normal for the top right part of the screen to be warm? All this happened when i upgrade to ios 10.1.1 5 days ago i don't know if that is the problem and i also have a little bit sweaty fingers and i dropped my phone for maybe 6 weeks ago i don't know what's the problem and i smelled the charger and heaphones port, sim card slot, the speaker, handset and the side of the screens it smells like mold or something is it bad?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
You may want to open the phone and reseat the display assembly cables using the iPhone 5 スクリーンの交換 guide. If that does not resolve the problem, you may want to replace the iPhone 5 Lightning Connector and Headphone Jack. If that does not fix the issue, then try the full display assembly replacement with a new part. As a last resort, you can try the iPhone 5 のロジックボードの交換, although I hardly think that will fix the issue.
iPhone 5 Lightning Connector and Headphone Jackの画像
製品
$19.99
iPhone 5 スクリーンの画像
ガイド
iPhone 5 スクリーンの交換
難易度:
中レベル
15 minutes - 1 hour
iPhone 5 ロジックボードの画像
ガイド
難易度:
中レベル
1 - 2 hours
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jdeang さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,154
