blue white power socket broken from mtherboard during hrd drive change
can this be repaired by me at home,with your help or does it require a solder at a computer shop or is my g4 destined for the bin?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
このアンサーは役に立ちましたか?
Your reference to yourself is better than mine. +
You can re-solder the socket back to the logic board. You can do the soldering yourself, or if you don't feel comfortable doing the soldering, then you can take it to a local repair shop and they may be able to do solder it for you.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 594
