Question 2: Why is my laptop taking so long to charge?
My laptop is taking a longer than usual time to charge. What could be causing this?
A common reason why your device is not charging as fast or as completely as before is that there is an issue with the charging cable. To remedy this, try inspecting where the cable plugs into the laptop. Use canned air to clean both the cable and where it plugs into the device. If charging problems persist, replace the cable as it is likely broken. If you still can’t charge your device effectively, follow this guide to replace your battery as it is likely dead or damaged.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 179
1件のコメント
Student Question
mayer さんによる
