Is the power supply dual voltage?
Old ps4 has dual voltage psu and what about ps4 pro?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Yes, all PS4's have dual voltage. Check out the first photo in step 8. You'll see that the power supply itself if rated for dual voltage.
このアンサーは役に立ちましたか?
Are you sure? I just bought an unit in Japan and the packaging, unit and manual says only 100V 50/60Hz. Even the model number is "CUH-7000B B01 100V"....
Yep...look at the link I posted above
I wonder why sony labelled the ps4s like that when they work on 110-250v range.
Who knows...the power supply is labeled correctly though.
So i dont have to worry of overheating or anything if i plugged the US PS4 Pro into a 220V supply ?
過去 24時間: 3
過去 7 日: 7
過去 30 日: 10
今までの合計 18,327
1件のコメント
Is the North American PS4 pro power supply a dual voltage
dejinas さんによる
