メインコンテンツにスキップ
Monochrome laser printer introduced in 2012. The printer is rated for 35 PPM and the first page comes out in 8 seconds. Depending on which model you own (a/n/dw/dn/dne), you will have different options and available features. Uses HP 80A/80X toner cartridges.
Why do I here a low whistle sound when printing?
Print jobs are fine. But low, loud whistle is heard when printing.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
The printer may be set up to use Quiet Print Mode. The engine speed gets reduced in this mode and it can make the printer whistle like this. If you know it's own or aren't sure, turning it off may get rid of it if it annoys you that much.
To do this on the 2 line LCD printer:
  • Go to System Settings
  • Find Quiet Print Mode
  • Change it to Off
If the noise remains, the motors are causing it. I would do your best to ignore it but if it bothers you they can be replaced but it's a difficult repair.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
how do i get to the spot to change i don't see quiet print mode
さんによる
I own the 2 line LCD model and that's what works for me. You must have a touchscreen variant.
I don't own one of these (nor easy access) so I don't know how but it's probably similar.
さんによる
コメントを追加
Most likely - It could be loud sound of toner cartridge, another version for that - fuser film needs to be oiled or replace due to insufficient amount of oil under it and worn out. Next thing I would check - is feed roller.
But I'm assuming - it's cartridge. If you have another one - try to put it in and check how it sounds to your ears.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
June Cross さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 2,363
