メインコンテンツにスキップ
2012年10月23日に発売されました。Core i5もしくはCore i7プロセッサ、Apple Fusion Driveを搭載しています。
Maximum hard drive thickness
I upgraded my Mac Mini a while ago to support two 1 TB drives (IF171-005-2), and I am now running out of space again. I have two spare 9.5mm thick 2 TB drives, I could use, but that doesn't increase the capacity much. However, Seagate is currently manufacturing 3, 4, and 5 TB drives, but at a 15mm thickness. What is the drive thickness limit for this Mac Mini? 9.5mm, 12.5mm, 15mm, or 19mm? Does the limit change if there is only one drive?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
The Late '12 models only has room for two 9.5 mm drives. My home system has two Samsung Spinpoint M9T 2 TB drives (now part of Seagate).
Only the newer Late '14 model can support a single HD that is 12.5 mm. As it has a blade SSD mounted in the lower bay (what you see when you pop the bottom plate off).
The space is fixed on both models so you can't steal the space to give to the other bay to make up the difference. But with that said, if you had access to a 3D printer I'm sure you could make a custom frame to allow you to do something different.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
philippe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 1,721
