メインコンテンツにスキップ
iPhoneを自分で修理するために必要なものはすべて揃っています!最新のiPhone 15から、2007年に発売された初代iPhone 2Gまで、iFixitにはすべてのiPhoneに対応する無料の修理ガイドと分解情報があります。
36478回答 すべてを表示
Screen flashes red when trying to recover with iTunes 4013/4014 error
When i boot up the iPhone 6 Plus I get the message to connect the iphone to itunes. I've tried recovering it with itunes but get the error codes 4013 and 4014.
Sometimes when recovering with iTunes the iphone flashes a red screen before rebooting again to an apple logo and then again: connect to itunes screen.
I've read some possible fixes on this forum: to remove the camera connector from the motherboard and starting up. I have done this (removed front facing camera and the main camera) but with no luck. I have the same red screen flash as before.
What could i do to fix this problem and have a working iphone again?
More information:
  1. Inside a few screws were missing (5 or 6)
  2. The waterdamage strips didnt recolour so no water damage as far as i see
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
it could be long screw damage or it could be the frontal camera. I check that out first though to see if there is any structural damage to the logic board
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Which one do i check out first? The frontal camera or for long screw damage? Should I just disconnect it and try to boot up again or should I order a new one.
I have tried to disconnect the frontal camera from the motherboard before and try to restore it again but the results were the same (not booting, red flash).
さんによる
コメントを追加
maybe there are some problem in the connection between your iPhone and PC, which cause you coun't recover your deleted data through iTunes. so how about trying to use a data recovery toolkit, such as iPhone data recovery, to assist to deal with this problem. if you could connect your iPhone to PC wiith USB, so you could recover your data. Actually, I also have suffered the same problems before, but luckily, I had got my deleted data back.
Read the following article to get more details about this method if you need. I hope it will work for you, too, and you could successfully. Good luck to you.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 657
