My tablet is not charging, how should I fix it?
My tablet keeps on connecting and disconnecting when it is plugged to the charger.
What is the problem? And how to fix it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The problem could be in one of the following elements:
Try to plug the charger in another device to determine whether it is what cause the problem or not. If the charger is not working then you would have replace it. On the other hand, if it working then you might have
a problem with the charging port.
Check on the Troubleshooting page for more information about a faulty charging port.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 8
今までの合計 592
