Battery temperature sensor error. TB3T
I replaced the battery, ram and SSD (in place of optical drive) in the macbook pro.
Since the fan has always been running on full (very noisy). I ran apple hardware test and it gave me the error TB3T.
Researching on webs, it says it battery temperature sensor issue.
Any ideas how to get the fan to behave and be quite?
Did you try my comment on your other question? "Try booting the Macbook with the wifi/cam/bluetooth cable disconnected. If this does not work, check around the charging IC for any burnt pins or components (just above the right side of the RAM sticks, with a 625 on the chip)."
Reece さんによる
