メインコンテンツにスキップ
Uniden model is G955. The serial number is H06311657. This is a 9" LCD monitor that is used for surveillance purposes that comes in a package with 2 wireless cameras.
Why is my monitor not charging properly?
Whenever I connect the charger to the monitor, I notice that my device's battery does not charge and it dies quickly after being connected to the charger for hours.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
First, make sure the charger is completely connected to the device and outlet properly. You may also need to test the charger with other outlets to ensure that the outlet is not the problem.
If the device still does not charge, connect your charger to another device to test that the charger is working. If this also fails, the battery may need to be replaced, please refer to Uniden Guardian G955 Troubleshooting Page
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Pauline Lara さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 29
今までの合計 3,723
