メインコンテンツにスキップ
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
64回答 すべてを表示
How to repair the dvd writer?
I brought a inspiron1545 in last year.it's warrenty expired.my systems Dvd writer is not working.plz tell me the solution.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
選択されたソリューション
It would be very helpful to know what the problem is with the DVD writer. If the drive cannot play dvd's or write to disks then yes the drive is probably bad and can be replaced easily for a relatively cheap price. If you just cannot see the drive in my computer then it is likely that you have corrupted registry drive filters. Microsoft has released a FixIt program to alleviate this problem and can be located here. Simply download and run the program and it should help you resolve this situation.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Good answer +
さんによる
コメントを追加
Unfortunately the DVD writer drive cannot be fixed. The easiest way is to buy a replacement drive and replace it in your computer or buy an external DVD writer.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
sairam さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 4,032
