How to repair the dvd writer?
I brought a inspiron1545 in last year.it's warrenty expired.my systems Dvd writer is not working.plz tell me the solution.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
It would be very helpful to know what the problem is with the DVD writer. If the drive cannot play dvd's or write to disks then yes the drive is probably bad and can be replaced easily for a relatively cheap price. If you just cannot see the drive in my computer then it is likely that you have corrupted registry drive filters. Microsoft has released a FixIt program to alleviate this problem and can be located here. Simply download and run the program and it should help you resolve this situation.
このアンサーは役に立ちましたか?
Good answer +
Unfortunately the DVD writer drive cannot be fixed. The easiest way is to buy a replacement drive and replace it in your computer or buy an external DVD writer.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 4,034
