メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung製の5メガピクセルビデオカメラで、2011年に発売されました。最大3メートルの水中、最大2メートルの高さからの落下に耐えられます。また、1080pでのビデオ録画が可能です。
Why does the battery discharge very quickly?
My camera's battery dies out very quickly. It seems like the battery life is getting worse day by day. It would not stay on for longer than an hour.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
There are many reasons why your battery is not performing the way it should be. Check the device troubleshooting page as well as the following tips to try fixing the problem:
1-Check your settings for any option that might be causing the battery to Drain quickly. if you cant find any try resetting the camera to factory settings.
2-How old is the battery? It might be time to replace it if you have had it longer than 3 years.
3- Check that the battery connections in your camera are not rusty. This may drain your battery faster than it should.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
Hi,
How long have you had the battery? Even rechargeable batteries have a life span.
If you have been using the same battery since new and have had it for 2-4 years, then depending on usage, the battery is most probably starting to fail.
Search online for a replacement battery for your camera. Just type Samsung HMX-W200 battery in the search box to get results. They are not that expensive.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Haya Barakat さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 37
今までの合計 557
