Why won't my tablet turn on?
Why won't my tablet turn on even when it's plugged in. Can you please help?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
First, ensure your charging cable and outlet are functioning properly. If one of these are not functioning, your tablet may just be dead and not able to charge due to a broken charging cable or outlet. If this does not restore power to your tablet, the battery is more than likely damaged and will need to be replaced in order to restore the tablet's functionality. Check out the troubleshooting page for the the Insignia Flex 10.1 NS-P16AT10 for more information about your tablet.
このアンサーは役に立ちましたか?
My tablet did the same thing. The thing that worked was me taking the tablet to the kitchen and throwing it away. Than I bought a Samsung tablet like I was should have done in the first place. No problem ever since. Hope this helps.
このアンサーは役に立ちましたか?
Mine just will charge 100% and it will let me go to the lock screen and the it will go to a black screen and blink the name in white for about 20 seconds then it will go back to the lock screen and it will do this over and over
このアンサーは役に立ちましたか?
My screen goes from black to a lighter shade of black and nothing appears and it will not reboot.
過去 24時間: 0
過去 7 日: 7
過去 30 日: 18
今までの合計 6,239
