My lincoln will ctank, but will not start. What could it be?
My lincoln town car has spark, but will not start. What do I check?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@sjeaquarius , More info. may of helped year, engine, any previous work done recently,etc. The first thing to check is there fuel in the tank/ is the security lite on/ check fuel inertia switch {if} equipped(look in your owners manual for location). You may have to have the vehicle scanned for trouble codes as a start as many things can cause your vehicle not to start, faulty crank sensor, Ignition module, coil packs, fuel pump, fuel pump relay, fuel pump, inertia switch if equipped, etc. Best to have a good Technician have a look, diagnose and estimate repair. Good luck. Link below may have more diagnosing procedures for you to check out.
https://www.2carpros.com/articles/car-cr...
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 129
