メインコンテンツにスキップ
The Roku 3 (Model: 4200) is a third generation streaming device released on March 5, 2013. Connect to any television or video display with correct input connections to stream available content.
Why is my remote not connecting to the Roku player?
I changed the batteries in my remote but it is still not working. My Roku does not respond even when I tried moving closer and made sure nothing was blocking the Roku player.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Make sure that the batteries are a fresh pair and have the same brand as each other. Using two batteries with different brands can cause one to empty before the other, leading to the remote not working.
Your remote may not be paired with your Roku device. Try re-pairing your remote by removing the battery cover and holding the pairing button until you see the pairing LED flash. If done correctly, a remote pairing notification should appear on your screen.
For additional information and troubleshooting support, check out the Remote section of our troubleshooting guide.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Isobelle Espiritu さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 689
