メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2690回答 すべてを表示
iPhone turns off when lock phone. Water Damage.
I accidentally sent my phone for a cycle in the washing machine, I left it to dry for a few days and then when the phone would not power past the initial white logo screen I ordered a new battery and replaced this. The phone is now fully operational when connected to the computer or mains via the charging cable, or when the screen is not turned off or the phone locked. When the phone is locked and not plugged in, the home and power buttons work on opening up the phone again for about a minute and then the phone will not power back on unless it is reconnected with the charging cable. The phone does not turn itself off randomly if it is connected via cable even when locked.
I have left the phone unlocked until the battery got down to 0%, tried a soft reset, a full reset via iTunes and this issue will not go away. Is this something I can fix by replacing a part inside the phone or is there a software fix?
Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
The charging system of your phone was damaged. Corrosion starts to set in as soon as power runs through the system and it sounds like lots of power has gone through it. Unfortunately, water damage is basically a death sentence for a cell phone. There are nearly countless components that could have been damaged and repairing the one that is causing your fault now, does not promise that more components won't fail in the future.
iFixit has a video on youtube regarding water damage and how its addressed.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
zophack さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 194
