Why is my laptop not charging?
Whenever I plug my laptop in, it doesn't charge. It only runs on battery power. I can't tell whether it is my adapter or my battery that is the problem.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Unfortunately, it is hard to determine if the battery or adapter is issue by just eyeballing it. If the adapter is the issue, you can test it by using another adapter, or simply buying a new one.
If the battery is the problem, then here is link to a guide that gives instructions on how to replace the battery:
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 1,757
