メインコンテンツにスキップ
1.83、2.0、2.1、 2.16、2.2、または2.4 GHzのいずれかのCore 2 Duoプロセッサーを搭載したModel A1181
1203回答 すべてを表示
Replace optical drive with SSD (light and cheap)
Hello,
I'm thinking of another project. how to:
1. reduce needless weight (2.27kg for a 13" is a lot)
2. insert 2nd SSD
So, I'm searching on the internet and I found OWC doubler costing 29$:
- https://eshop.macsales.com/item/OWC/DDAM...
The idea of plastic holder seems great but not ideal for 29$. Is there any other plastic-based converter closer to this price?
- https://www.amazon.com/ZXUY-Unibody-Univ...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
First thing here is the optical drive in this system is PATA not SATA! So you need a carrier that converts between the different interfaces which limits you to a much smaller set of units.
Here's the IFIXIT unit: 9.5 mm PATA Optical Bay SATA Hard Drive Enclosure
The other problem you face is you'll need to find a SATA I (1.5 Gb/s) or a SATA II (3.0 Gb/s) SSD as the converter logic is only rated to SATA II.
The next rub is the throughput will be much less (about 800 Mb/s) which is the limit of the PATA interface
While I commend you of your efforts to make a lighter system there are limits on what you can do here.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
tsoump さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 74
