repair craked camera glass
is it possible to repair cracked camera glass on the back side iphone 7 ?
if so, how much is it??
I don't know how much they charge for it in your country, but with a little bit practice you should be able to do it by yourself:
このアンサーは役に立ちましたか?
I haven't seen anything for it, honestly. I'm sure if you could come across a part that it would be somehow possible (not sure the details or difficulty of course, but nevertheless)
このアンサーは役に立ちましたか?
I found one on eBay in about 10 seconds.
Here's a link:
このアンサーは役に立ちましたか?
Never actually checked, thanks for the link man! :D
Your welcome :)
It would be easier in my opinion to just replace the whole back housing
このアンサーは役に立ちましたか?
Actually it would be a lot harder, a housing replacement would be an hour, a camera glass would be a minute.
i thought should be taking off the rear housing first then you can remove the rear camera glass from outside to inside
Has someone made it? Maybe he can give us some advices? How to disassembly the lens ?!
Here is a Video-Tutorial:
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 25
今までの合計 294
1件のコメント
How in god's name did you already manage to do that
Kristof Ferenczi さんによる
