Help! My fan is so loud! What is going on?
My HP ProBook 4520s fan is really loud and seems to be running a lot. My laptop is warmer than usual too.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Its a common sign that your computer might be dusty inside. On top of that, your laptop is about 6 years old now.
When your fan starts going crazy, open "Windows Task Manager" (By pressing Ctrl + Shift + ESC key on your keyboard).
When "Windows Task Manager" shows up, go to the "Processes" tab, click on "CPU" and take a screenshot using "Snipping Tool". Once that's done, go to the "Performance" tab and take another screenshot.
How to open "Snipping tool"
"Windows Task Manager" Processes and Performance tabs
Reply to this question and post your pictures here. We might be able to help you out. I have a feeling you might have a lot of programs opened at the same time, thats why your computer fan is going crazy.
このアンサーは役に立ちましたか?
if taking away the dust only makes the fan work les often, but doesnt help with the noise it makes when it runs, your fan probably has a liquid bearing. if it is constantly noisy when it runs the bearing is dried out. you should take the fan out of your laptop and use some silicone spray on the bearing to make it wet again.
このアンサーは役に立ちましたか?
I have a 2016 HP notebook that made a terribly loud revving noise whenever it ran. Greasing the bearings worked for me.
Your fan might be dusty so try cleaning the fan vents. Take a look at the troubleshooting page for additional help on the issue.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 5,628
