How do I reset my tablet?
I want to reset my tablet back to the way it was when I first bought it, without all the other extra apps I installed.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You can power off the tablet by holding the power button. Then press and hold the volume UP button and the power button simultaneously. This will bring you to a menu called “Android System Recovery <e3>.” Scroll to the option “wipe data/factory reset” using the volume buttons and select it using the power button. This should work.
このアンサーは役に立ちましたか?
no no no nothing works
I have the same problem. But tablet will not shut off with powee button
I can't reset mine no how no way. My grandson changed the # ive tried doing it like the video says. Nothing. Huh!!
Worked for me, thank you
No me entra el modo recovery
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 10,123
3 件のコメント
Go to RCA RCT6203W46 Troubleshooting for more help!
Alexis Roberson さんによる
Has anyone else noticed that no-one gives a n answer here . . .
Saving Civilrights さんによる
@alexisr I need help fixing my tablet
Amber Hicks さんによる
