メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
iPhone 6 no sound
i have an iPhone 6 and one day i opened it to replace the battery after i start it up
i noticed that the iPhone has no sound at all when i open youtube app shows an error Playback Error , snapchat won't load videos instagram too and i pluged in the headphones and the sound work perfect when i connect with a bluetooth speaker the sound work perfect too. i tried to change the speaker change the chargning port but no luck. i have more .. when the phone is on and i plug the headphones don't show me the volume HEADPHONES but Ringer so i have to reboot my device to activate the headphone mode
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
My guess is you broke the power/volume flex when removing the battery. Did you have to use pry tools to change the battery or did you use the pull tabs?
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
no i know how to remove the battery just by pulling out the glue under it but it's not the problem there i have replacet the motherboard (my motherboard) into another iphone 6 (works very well) but my motherboard still do not support sound in any speakers
さんによる
Good. I'd still try a new volume flex. Its a good starting point.
さんによる
コメントを追加
Hello. In my opinion it's not volume flex damaged. But ive got questions for You :
1) Does your phone getting lag when trying to rec a video, or trying to watch any video with sound on YT
2) Does Phone lag while some1 calling you, when you have sounds turn on , and does he works properly when you have sounds off ?
When phone works properly on headphones You could have damaged sound IC, it's very expensive in repair, and very dangerous, beacause its "under" screen connections on Mainboard.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Adrian Zymeri さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 257
