メインコンテンツにスキップ
2012年10月23日に発売されました。Core i5もしくはCore i7プロセッサ、Apple Fusion Driveを搭載しています。
208回答 すべてを表示
Upgrading 802.11n to 802.11ac
The Apple developers forum confirms that the new Auto Unlock with Apple Watch feature offered in MacOS Sierra works only with an 802.11ac, not with an 802.11n.
So if you want this feature to work, you will have to replace your <2012 n with an ac board.
The question then is the part number that corresponds to the 802.11ac that works in a <2012 MBM.
Update (01/22/2017)
Yes. Mac Mini.( And some more characters to meet the minimum requirement.)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
4 件のコメント
What is your exact system here and model. Your TLA MBM doesn't make sense. MacBook Mini??
さんによる
Bumping this as Dan is %100 right, you'll need to find the model number.
If you don't know how, use this: https://support.apple.com/en-nz/HT201894
If you post the Model number we'll be able to tell you if your MbM supports an upgraded WiFi card and what one you can upgrade it with.
さんによる
Hi, I am looking at upgrading my wireless to ac also. I have validated my serial number via the link above and it confirms that I have a late 2012 Mac Mini. Can you please let me know the relevant part number for an ac wireless board?
さんによる
Have either of you had any luck or figure out another solution? Thanks!
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Sadly the Airport boards are very different between the 2012 and 2014 models:
2012 board
2014 board
There is no upgrade option available. For a short time Broadcom offered some engineering samples which some people were able to get (long since gone).
Broadcom never offered a production part as Apple went with the mini-PCI interface board in the 2014 model.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Joseph Lough さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 8
今までの合計 4,625
