My screen flickers then becomes unresponsive?
When I power on my laptop the screen is quite dim, after login the screen flickers and then goes black and ultimately becomes unresponsive . What can I do to fix this?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The display connectors inside the device may be loose or faulty. You will need to open up your device to clean this connector and try to re-seat the connector. If that is not a solution to this problem you may need to replace the connector entirely. For a link to troubleshooting this device click here.
このアンサーは役に立ちましたか?
That sounds like the connection to the display is bad. I have fixed this before just by cleaning the connectors before. Try this guide to get to the connectors: http://support.hp.com/us-en/document/c04...
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 3
過去 30 日: 17
今までの合計 1,641
