D pad sticking on ds lite
The d pad on my ds lite (left,right,up,down buttons) the right button sticks sometimes it responds other times not when you press it seems like you need to put a lot of pressure on it . Takes the fun out of gameplay
Hi,
Best approach is to open the console and make a full clean of the rubber and electronics connector beneath the D-Pad.
In some cases the rubber gasket could be broken due to extended use, if such the case you will need to replace it.
I am not sure if rubber piece is sold individually (I have plenty of it, but I am in Montreal, Canada). To get a replacement you will need to order a whole case where replacement are included.
Good luck and good repair.
JM
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 13
今までの合計 1,027
