My laptop cannot power on.
My Alienware laptop cannot power on. No response after pressing power.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
derekseven you want to start off by checking the output of your AC adapter with a multimeter. If the output is correct for your model (you did not tell us which model you have) then you need to consider taking it apart and measure/check the DC in connector. Try and trace the power loss from there on. If you give us your computers model number we may find a more direct answer.
このアンサーは役に立ちましたか?
Same issue with a r2 15 , gtx 980m. It stopped whilr i was gaming and didn t start back. Doesn t turn back on.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 9
今までの合計 247
