screen black but computer on
Computer is on but screen very dark almost back. Tried to reset P ram & also took out memory cards & then re-inserted. Still black screen. What to do?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Can you still see a faint image on the screen? If yes, try AussieMacs suggestion. If that fails than most probably your inverter board is gone.
Look at this MacBook Core 2 Duo Inverter Replacement.
The inverter controls the backlight of the screen and is cheaper than a new LCD. There is, however, the faint change that the backlight itself failed. Than you do have to replace the LCD.
このアンサーは役に立ちましたか?
+ To check this out hook it up to an external monitor.
There is an easy way to handle your problem; maybe you can try the software "tuneup360". My friends and I all use it, which can help you fix all the problems you may encounter.
このアンサーは役に立ちましたか?
That's just wonderful if you have a PC. I believe the poster is using a Mac.
過去 24時間: 0
過去 7 日: 5
過去 30 日: 5
今までの合計 1,814
